Problem Cisco AIR-LAP1131AG-E-K9 Ethernet LED = Off; Radio LED = RED ; Status LED = RED ;
ngchinh01
hi,
I have a Cisco AIR-LAP1131AG-E-K9 when I boot one accesspoint it gives  Ethernet LED = Off; Radio LED = RED ; Status LED = RED  and only next listing in the screen:
Xmodem file system is available.
Flashfs[0]: unable to allocate available block.
The system has been interrupted, or encountered an error during initializion of the flash filesystem.
The foolowing commands will initialize the flash filesystem, and finish loading the operating system software:
flash_init
ether_init
tftp_init
boot
When I type this commands, it doesn't help at all. The output will be following:
ap: flash_init
Initializing Flash...
flashfs[0]: out of memory
...done Initializing Flash.
ap: ether_init
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ap: tftp_init
Unable to get our ip address: no "IP_ADDR" variable set
ap: boot
Loading ""...; permission denied
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
ap:
what i do ?  please help , thanks
Sandeep Choudhary
HI,
Try with mode button:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
It might help.
***Dont use PoE swicth as power source.
hi Sandeep
i try to this guide :
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Set the timeout value on the TFTP server to 30 seconds.
Step 4 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View; then uncheck the Hide extensions for known file types check box.
Step 5 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 6 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 7 Disconnect power from the access point.
Step 8 Press and hold MODE while you reconnect power to the access point.
Step 9 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 10 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 11 After the access point reboots, reconfigure it using the GUI or the CLI
but still have prolem , can't put ip adress 10.0.0.1 to AP.
