Problem Enable Wirelles
engividal
Community Member
I have a model with ap wap321-A-K9 V01
problems when enabling wifi .
when I enable the radio Wireless>Radio>Basic Settings>Enable
The AP restarting and back to factory settings. I updated firmware.
My current firmware version is 1.0.4.4. But the problem persists.
We have only one network configurated on it, I've attached a file with the exported diagnostics.
Very sorry to hear about that.  It sounds like you need to RMA this unit.
Charlie Moreton
It seems that is AP is optimized to use the GUI for configuration.  Have a look at the Administration guide found here:
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
It's not the easiest document to find, but I hope it helps you.
Please Rate Helpful posts and mark this question as answered if, in fact, this does answer your question.  Otherwise, feel free to post follow-up questions.
Charles Moreton
Hi Charles,
I already read this document and follow the wizard to configure the initial AP but at the end it restarts and back to factory settings .
Thank you for your help!
Thanks for you answer Charles.
