Problem login gui wlc9800
omarsh
Community Member
Hi Community,
I can't login to my controler wlc9800,
How I can disable this config from CLI.Capture d’écran 2022-12-12 224057.png
Best regards.
balaji.bandi
what code running, i see some issues with Chrome, after the upgrade to 17.6.4 it was fixed.
try firefox
BB
Scott Fella
So the screen shot is prior to hitting apply?  If you are on the cli, all you have to do is run the following command and the delete the line that you entered before it was broke.
show run | in ip http
show start | in ip http
The above will show you the commands that were configured.  If you didn't save the config you can always copy start run.
-Scott
