problem ofbroadcast.
tushar47
Level 2
Level 2
Dear sir,
I am running RF link between 2 locations on Cisco Aeronet modem. The link runs perfect with normal latency, when there is not any broadcast. But when it is connected to PCs through server, broadcasts start coming. And the latency goes very high.
Please help me to troubleshoot the problem.
Ashu
mchin345
Level 11
Level 11
Are you running any authentication protocols, if you are try removing them and check if it works properly.
