Problem :Printer service and wireless
o-garcia
Community Member
When we try to configure a printer and the PC card is working, the PC doesn´t respond, but if we take off the PC card and configure the printer, the PC works ok...
Do you think the signal is causing the problem.???
smahbub
Level 11
Level 11
It sounds like some sort of conflict. You might run it by Cisco’s tac to see if they have seen any issues similar.
