Problem switching between SSID's within Wifi Controller AIR-CT2504
cisco-mssa2007
Hello
I configured a 2504 controller with two LWAPP Access Points, and I'm using two SSID's on the same controller, the problem is when the user tries to switch between SSID's he gets an error message saying that the other network is unavailable but if he disconnects from the first network and then connects to the other it works fine !.
My user ask me to solve this issue, do you have something like this reported ?
2 Accepted Solutions
Scott Fella
On the Controller tab, make sure Fast SSID Change is enabled.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
That should work... let us know if it doesn't.
Scott
-Scott
5 Replies 5
Scott Fella
Scott
-Scott
Scott
-Scott
Thank you very much Scott, I'll try it.
Scott
-Scott
Scott
THANK YOU
You are right, that worked just fine. Thanks a lot !
