Problem when installing CMX 10.6.3-70
RBordais
Visitor
I am posting here to find out if you have any ideas about my problem when installing the CMX in version 10.6.3-70 following a crash (?) of the VM.
The context is as follows for the MSE:
- AIR-MSE-3365-K9 in BIOS Version C220M4.4.1.2e.0.0615220033
- CIMC in Firmware 4.1(2k)
I followed Cisco's procedure (https://www.cisco.com/c/en/us/td/docs/wireless/mse/10-6-3/installation/installation_guide_1063/software_reset_of_mse_3365_device.html) but towards the end of the installation process, I have the following error:
Restarting network...
Pinging 127.0.0.1..... Success
Pinging X.X.X.X ..... Success
Traceback (most recent call last):
File "/usr/local/lib/python2.7/runpy.py", line 174, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/local/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/opt/cmx/sw/lib/pymodules/cmxos/__main__.py", line 1120, in <module>
cmxos()
File "/usr/local/lib/python2.7/site-packages/click/core.py", line 716, in __call__
return self.main(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/usr/local/lib/python2.7/site-packages/click/core.py", line 1060, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/local/lib/python2.7/site-packages/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/local/lib/python2.7/site-packages/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/opt/cmx/sw/lib/pymodules/cmxos/__main__.py", line 98, in configure
cmxos.cmxOSConfig(force, skip)
File "/opt/cmx/sw/lib/pymodules/cmxos/cmxosconfig.py", line 235, in cmxOSConfig
self.cmxNetworkConfig()
File "/opt/cmx/sw/lib/pymodules/cmxos/cmxosconfig.py", line 93, in cmxNetworkConfig
testnet = self.testNetworkConfig()
File "/opt/cmx/sw/lib/pymodules/cmxos/cmxos.py", line 431, in testNetworkConfig
return ret1 and ret2 and ret3 and ret4
UnboundLocalError: local variable 'ret3' referenced before assignment
** Something went wrong with the installation, it did not exit cleanly
** Please fix the errors and reboot, login as cmxadmin to start over
I don't know what to do, do you have an idea? Thank you and have a good day.
Mark Elsen
 - I would advice to create a new VM and start the installation from scratch (again) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
RBordais
Visitor
Indeed, starting from scratch was necessary... this allows us to start on a good basis!
Thanks.
