Problem Wifi
DWAM_2
Level 6
Level 6
we are using guns Teklogix with embbeded cisco card associated (model CB20A) with AP 1200.
It worked very good : no loose communication.
We were using two radius server AP with LEAP.
We did few changes one month ago :
-> changing ip adress of gun (static to static)
-> upgrade IOS on AP.
-> using 2 vlans for ap (1 for administration, 1 for using gun)
-> changing the radius from AP to extern radius servers as ACS.
-> using WDS with WLSE.
Since these changes, we have got problem :
Randomly, the gun blocks : we're loosing communication between gun and ap.
We have seen that the gun is well associated with ap (on http menu)
but we don't arrive to ping the gun.
The workaround is to restart the gun.
DWAM_2
Level 6
Level 6
There are lot of roaming on the site, here are the follow output of the syslog from 2 AP and Acs Passed Authentication:
10:30:45 AP01 4045: Jul 5 10:31:00.988: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Associated KEY_MGMT[NONE]
10:31:00,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19176,172.17.88.53
10:33:50 AP01 4046: Jul 5 10:34:05.895: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.ed77.de24
10:33:50 AP03 14796: Jul 5 10:34:05.894: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:33:50 AP01 4047: Jul 5 10:34:05.895: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
05/07/2005,10:34:05,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19183,172.17.88.53
10:34:12 AP01 4048: Jul 5 10:34:28.072: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:34:12 AP03 14797: Jul 5 10:34:28.074: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.bc68.3153
10:34:12 AP03 14798: Jul 5 10:34:28.074: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:34:28,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19184,172.17.88.53
10:34:33 AP01 4049: Jul 5 10:34:49.005: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.ed77.de24
10:34:33 AP01 4050: Jul 5 10:34:49.006: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:34:48,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19186,172.17.88.53
10:37:07 AP01 4051: Jul 5 10:37:22.871: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:37:07 AP03 14804: Jul 5 10:37:22.872: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.bc68.3153
10:37:07 AP03 14805: Jul 5 10:37:22.872: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:37:22,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19189,172.17.88.53
10:38:39 AP03 14806: Jul 5 10:38:54.870: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:38:39 AP01 4052: Jul 5 10:38:54.871: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.ed77.de24
10:38:39 AP01 4053: Jul 5 10:38:54.871: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:38:54,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19190,172.17.88.53
10:39:34 AP01 4054: Jul 5 10:39:49.817: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:39:34 AP03 14807: Jul 5 10:39:49.818: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.bc68.3153
:39:34 AP03 14808: Jul 5 10:39:49.818: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:39:49,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19191,172.17.88.53
10:44:25 AP01 4055: Jul 5 10:44:41.562: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Previous authentication no longer valid
10:44:29 AP03 14817: Jul 5 10:44:45.439: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Associated KEY_MGMT[NONE]
10:44:45,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19199,172.17.88.53
10:45:53 AP01 4056: Jul 5 10:46:09.520: %DOT11-6-ASSOC: Interface Dot11Radio0, Station FRDKOWH09 0011.211a.0eca Reassociated KEY_MGMT[NONE]
10:45:53 AP03 14820: Jul 5 10:46:09.521: %DOT11-6-ROAMED: Station 0011.211a.0eca Roamed to 000d.bc68.3153
10:45:53 AP03 14821: Jul 5 10:46:09.521: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0011.211a.0eca Reason: Disassociated because sending station is leaving (or has left) BSS
10:46:09,Authen OK,Qh9Bv1kL,Utilisateurs WIFI,0011.211a.0eca,19201,172.17.88.53
You can see that we have got the error message : Previous authentication no longer valid.
Thank you for your help.
Best regards.
