Problem with AIR-CAP3602I-E-K9
leofalconi
Yesterday I had a problem with the AP AIR-CAP3602I-E-K9.
The AP is connected with a WLC 5508.
The disservice has been for few seconds.
The logs are these:
1 14:40:00.675: %DOT11-6-ASSOC: Interface Dot11Radio1, Station  4c66.419b.cb74 REAP Associated KEY_MGMT[Open]
*Feb  1 14:40:14.119: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station c0bd.d1a5.a8c6 Sending station has left the BSS
*Feb  1 14:40:23.719: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4c66.419b.cb74 Sending station has left the BSS
*Feb  1 14:41:05.227: Received and decoded a DMS client request payload SUCCESSFULLY
*Feb  1 14:41:20.435: Received and decoded a DMS client request payload SUCCESSFULLY
*Feb  1 14:43:40.727: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 9c4f.da5c.4606 Sending station has left the BSS
*Feb  1 14:43:41.323: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 90b2.1f02.2398 Sending station has left the BSS
*Feb  1 14:43:45.339: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 380f.4a8e.5aab Sending station has left the BSS
*Feb  1 14:43:45.383: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a94.e22c Sending station has left the BSS
*Feb  1 14:43:45.415: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8b.40f5 Sending station has left the BSS
*Feb  1 14:43:45.439: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 90b2.1f01.3f56 Sending station has left the BSS
*Feb  1 14:43:45.439: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8f.d679 Sending station has left the BSS
*Feb  1 14:43:45.515: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a97.c404 Sending station has left the BSS
*Feb  1 14:43:45.515: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8e.6146 Sending station has left the BSS
*Feb  1 14:43:45.539: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a95.5b0a Sending station has left the BSS
*Feb  1 14:43:45.595: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a94.81e0 Sending station has left the BSS
*Feb  1 14:43:45.595: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a90.feec Sending station has left the BSS
*Feb  1 14:43:45.703: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 748d.087f.fced Sending station has left the BSS
*Feb  1 14:43:45.711: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a89.bb12 Sending station has left the BSS
*Feb  1 14:43:45.727: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8c.b492 Sending station has left the BSS
*Feb  1 14:43:45.731: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8a.c634 Sending station has left the BSS
*Feb  1 14:43:45.803: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8d.16c5 Sending station has left the BSS
*Feb  1 14:43:45.803: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8d.8bce Sending station has left the BSS
*Feb  1 14:43:46.219: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a92.7da4 Sending station has left the BSS
*Feb  1 14:43:46.307: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station d033.11c8.ba69 Sending station has left the BSS
*Feb  1 14:43:46.695: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 90b2.1f00.9c79 Sending station has left the BSS
*Feb  1 14:43:46.743: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8e.6131 Sending station has left the BSS
*Feb  1 14:43:46.743: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a89.fc86 Sending station has left the BSS
*Feb  1 14:43:46.775: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station a888.08d2.8c99 Sending station has left the BSS
*Feb  1 14:43:46.775: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 380f.4a8e.07a6 Sending station has left the BSS
*Feb  1 14:43:47.427: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station a866.7f82.5e69 Sending station has left the BSS
*Feb  1 14:43:49.407: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 90b2.1f01.2396 Sending station has left the BSS
*Feb  1 14:43:59.351: %EVT-4-WRN: Write of flash:/event.capwap done
*Feb  1 14:43:59.375: %LWAPP-3-CLIENTERRORLOG: Switching to Standalone mode
*Feb  1 14:43:59.395: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.2.0.100:5246
*Feb  1 14:43:59.479: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Feb  1 14:43:59.483: %CLEANAIR-6-STATE: Slot 0 down
*Feb  1 14:43:59.483: %CLEANAIR-6-STATE: Slot 1 down
*Feb  1 14:44:10.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.2.0.100 peer_port: 5246
*Feb  1 14:44:10.303: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.2.0.100 peer_port: 5246
*Feb  1 14:44:10.303: %CAPWAP-5-SENDJOIN: sending Join Request to 10.2.0.100
*Feb  1 14:44:11.703: %LWAPP-4-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash
*Feb  1 14:44:12.095: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller WLC-1
*Feb  1 14:44:12.171: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Feb  1 14:44:12.171: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Feb  1 14:44:12.171: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration fileWLAN id 1, SSID MB-Meeting, L2ACL , L2ACL AP
WLAN id 3, SSID Corporate, L2ACL , L2ACL AP
WLAN id 4, SSID Guest, L2ACL , L2ACL AP
*Feb  1 14:44:12.247: %LWAPP-3-CLIENTERRORLOG: Switching to Connected modecapwap_delete_all_l2Acls_in_nacl_list:336. Deleting all L2Acls in AP config
*Feb  1 14:44:13.407: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Feb  1 14:44:13.911: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a94.81e0 REAP Associated KEY_MGMT[Open]
*Feb  1 14:44:34.227: %CLEANAIR-6-STATE: Slot 0 enabled
*Feb  1 14:44:36.275: %CLEANAIR-6-STATE: Slot 1 enabled
*Feb  1 14:44:40.391: %DOT11-6-ASSOC: Interface Dot11Radio1, Station  c0bd.d1a5.a8c6 REAP Associated KEY_MGMT[Open]
*Feb  1 14:44:43.079: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f099.bfd3.7a65 REAP Associated KEY_MGMT[Open]
*Feb  1 14:44:43.695: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a95.5b0a REAP Associated KEY_MGMT[Open]
*Feb  1 14:44:44.583: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a8a.c634 REAP Associated KEY_MGMT[Open]
*Feb  1 14:44:45.571: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a90.feec REAP Associated KEY_MGMT[Open]
*Feb  1 14:45:10.507: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   d81d.72a5.2cd3 REAP Associated KEY_MGMT[Open]
*Feb  1 14:45:26.519: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f099.bfd3.7a65 Sending station has left the BSS
*Feb  1 14:45:26.543: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   f099.bfd3.7a65 REAP Associated KEY_MGMT[Open]
*Feb  1 14:45:55.907: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   748d.087f.fced REAP Associated KEY_MGMT[Open]
*Feb  1 14:46:05.315: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a89.fc86 REAP Associated KEY_MGMT[Open]
*Feb  1 14:46:11.911: %DOT11-6-ASSOC: Interface Dot11Radio1, Station  4c66.419b.cb74 REAP Associated KEY_MGMT[Open]
*Feb  1 14:46:30.515: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station c0bd.d1a5.a8c6 Sending station has left the BSS
*Feb  1 14:46:34.911: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 4c66.419b.cb74 Sending station has left the BSS
*Feb  1 14:46:42.703: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a8e.5aab REAP Associated KEY_MGMT[Open]
*Feb  1 14:46:59.739: %DOT11-6-ASSOC: Interface Dot11Radio1, Station  c0bd.d1a5.a8c6 REAP Associated KEY_MGMT[Open]
*Feb  1 14:47:18.411: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a8e.6131 REAP Associated KEY_MGMT[Open]
*Feb  1 14:47:58.279: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   380f.4a94.e22c REAP Associated KEY_MGMT[Open]
*Feb  1 14:48:05.679: Received and decoded a DMS client request payload SUCCESSFULLY
Do you have any suggest for resolve this problem?
Thank you,
Leonardo
pieterh
Looks like the problem "solved itself"?
Th AP has lost the connection to the wireless controller for some reason.
and regained connection after some time.
possible reasons could be
- controller reboot
- some network path (switch or router) in the path unavailable
  maybe a spanning-tree issue?
Of course the forum cannot determine this cause from a distance 😞
You need to look into the rest of your network devices.
