Problem with autonomous AP at NCS
Hey all,
got the following problem at NCS:
Upgraded alot of APs with the migration template. One access point remains as an autonomous one (it's a lightweight now).
If I try to delete this one I got the error message in the screenshot.
What can I do now?
Thanks in advance.
Scott Fella
Have you tried to refresh the config? Also, you have that ap on the map and it is grey'd out? Maybe you can take the ap down and then try to remove it from NCS.
-Scott
