Problem with Client Disconnect
jcardozo
Community Member
I Have problem with Client Disconnect, we use WLC 4400 and LAP 1250 configured with HREP mode. Some clients are disconnect, how can I do Trobleshooting about that ?
Vinay Saini
Hii
when you are facing this issue is ur HREAP AP is connected mode ?
What are the authentication type used for the client ?
1. Issue the command "debug client " on the controller to further debug
2.Sniff the air with the client MAC address on the channel where client is connected using omnipeek.
Vinay
The client debug is a good place to start and here is a document explaining that process.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008091b08b.shtml
You many want to do dot11 debugs as well. But sniff the air first and see what activity you see... Also check your clients for a possible misconfig.
