Problem with Input queue vs output errors
m-avramidis
Level 3
Level 3
Frankly, i don`t understand how theese two different errors can so to say "correspond" to each other.
At this client site i use 1120 b/g. I had to turn off everything above the "b" specification to make this work sínce the Symbol based handheald PocketPC was`nt able to support the "g" standard/specification. I`ve also raised the "hold-queue" size to 1500 on the incoming (dot0) traffic on the AP. Below are an output from the dot11 interface:
"Dot11Radio0 is up, line protocol is up
Hardware is 802.11G Radio, address is 0012.0191.7360 (bia 0012.0191.7360)
MTU 1500 bytes, BW 11000 Kbit, DLY 1000 usec,
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 02:42:02
Input queue: 0/1500/209/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/30 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
2477 packets input, 211512 bytes, 0 no buffer
Received 133 broadcasts, 0 runts, 0 giants, 0 throttles
14912 packets output, 1177069 bytes, 0 underruns
218 output errors, 0 collisions, 0 interface resets
0 lost carrier, 0 no carrier
0 output buffer failures, 0 output buffers swapped out"
Should i apply WRED as a QoS solution instead of fifo?
can anyone help me with this???
