aes/tkip and broadcast-key rotation
o-ziltener
Is it right that broadcast-key rotation is only used with dyn. wep?
Is the combination of aes or tkip with broadast-key rotation idle?
any input is very welcome
Oliver
kecampbe
Broadcast key rotation can only be used with authentication methods that allow for dynamic keys. In other words, if you are using some kind of EAP-based authentication, you should be able to use BKR.
When you are using static WEP, then BKR cannot be used with those clients.
Kent.
