Problem with Local Authentication
bdcvc
Community Member
We are trying to get Local Authentication to work on a MR33 access-point with latest firmware.
We already checked message:
https://community.meraki.com/t5/Wireless-LAN/Local-Auth-issues-with-Android-devices/m-p/196714
Our infrastructure is as follows :
- Azure AD environment with Intune
- Scepman certificate service
- Client Certificate CA installed : Scepman Root CA
- LDAP Server CA installed : {our Azure LDAP cert.)
The LDAP Server test (built-in test tool in GUI) is succesful.
A windows 10 client with both Client and Root CA certificate installed cannot connect to the (SSID) network.
A Wireshark packet capture only shows initial connection to the AP, but there is no response from the AP.
The capture also does not show any traffic to our Azure LDAP server.
We will appreciate any help in solving this issue.
Thanks.
bdcvc
Community Member
Hi, we just resolved this issue.
Solution : Install the IdenTrust Root CA 1 certificate on your end devices.
Please refer to : : https://documentation.meraki.com/MR/Encryption_and_Authentication/Meraki_Local_Authentication_-_MR_802.1X
aleabrahao
Meraki Community All-Star
Can you share the error you are receiving?
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
bdcvc
Community Member
