Problem with Radius web authentication
ms.nfm
Community Member
Dear experts,
We have a setup of several 4402/4404 wlc's on site and one 4402 wlc anchor controller.
Also a guest server version 2.0.0 is implemented.
Corporate wireless works fine, my problem relies in guest access.
All wlc's on site are linked fine to the anchor controller, paths are up/up.
My clients recieve a ip address successfull from the anchor controller.
First web attempt redirects to the authentication web page, also fine though.
I create a guest account and try to login which where it goes wrong. I have setup PAP authentication on my anchor controller so that should be fine. When I debug the logs on the guest server i conclude that the password is encrypted so the guest server concludes it's wrong and sends a reject. Why does this server encrypts the password so my authentication fails??!! please help me with this i've could a bit stuck on this..
ms.nfm
Community Member
So the day i post my message i already found the bug myself. The problem in my case was that i copied the credentials from the form the guest server 2.0 created for a guest. But, when you copy username/password you also copy a space..so when you copy this to your authentication process the credentials will be wrong!!!!! unbelievable...
