Problem with wireless phones CP 7921-G
Adrian Leon
Hi good day sorry.
I'm new to this, but it's a start.
I have a question for you. I am working as a network administrator IP phone, the company made ​​a firmware upgrade to CUCM version 8.5, the following versions was that wireless phones CP 7921-G are also updated the firmware to function better with CUCM 8.5, but since this happened,
maybe you hear better than previous versions,
but there is a lot of packet loss, the comuniacion not understood, users complain too much about the wireless phone system.
We could help with any suggestions on how to improve service.
Thanks for your attention
4.0.217.0 code? My freind this code is so old that its not supported, at last check. If you called TAC, I bet they would recommend you upgrade. This is YEARS old.
I would look at getting that code upgrade first. Just my 2 cents
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
15 Replies 15
Stephen Rodriguez
What version did the phones get upgraded too?
Hopefully they are on 1.4(4)
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
migilles
Need to ensure the 792x phones are running 1.4(3) or later if connecdting to a 11n AP.
1.4(4) is recommended as Steve mentioned.
These system Information.
Entire network CAT 6
25 unit CP 7921-G System Load ID CP7921G-1.4.2.LOADS
25 unit Air-lap1121g-a-k9 IOS Version 12.3(11)JA3
Cisco 4400 series Wireless LAN Controler Model 4402 Version 4.0.217.0
Cisco Unified CM Administration System version: 8.5.1.10000-26
I wonder, what are the latest versions for WLC,
and which version is the one that will work best system?
where I can find a little more information
Thanks for your attention George
regards
See the guide that I posted a link to.
We currently recommend 7.2.110.0, 7.3.101.0 or 7.4.100.0.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Yeah 4.0 is not a supported verison any longer.
Should at least be a minimum of 6.0.202.0 or 7.0.235.0, but the AP1120, which is 802.11b/g only, may not be supported in some of those later releases.
1.4(2) should work ok with the 1121 though.
But the WLC version is definitely in question.
Below is my 7921G Deployment Guide, which lists supported versions, APS, and other info.
i recall the 1120 is support past 4.0 code so long as it has a g radio. b only radios will not work. but you cant go back 7.0 code as these aps dont have enough memory.
George Stefanick
The first thing I would do is make sure your wireless network is designed to support voice. If it is not then we need to fix that first.
If it is designed properly then we need to look at code revs used on the wifi side and the phone side . If that checks out ..
I would then look at client debugs
Adrian Leon
Thank you for your advice, I need more information to upgrade WLC which could advance without changing the AP
Take a peek at this link it shows code and aps supported
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_116_0.html#wp610751
This is up to 7.0.116.0 .. But this would be for all 7.0 code .. Your controller (4400) doesnt support ANY code past 7.0 code. You cant go to beyond 7.0 code ..
migilles
Please DO NOT us 7.0.116.0.
Use 7.0.235.0 or later instead.
Yup .. I only had the 7.0.116.0 link handy ;)
What about the lastest 7.0.24x ?
then my controller, if you accept the version 7.0.235.0?
