Problem with WiSm 5.2.157 AP authentication
n.allisat
Hello
I have a problem with an AP which is not joinig the wism. The log at the wism tells me:
*Oct 12 14:07:08.866: %LWAPP-3-RADIUS_ERR: spam_radius.c:138 Could not send join reply, AP authorization failed; AP:
*Oct 12 14:07:08.856: %LWAPP-3-PAYLOAD_MISSING: spam_lrad.c:6008 Join request does not contain BOARD_DATA payload
*Oct 12 14:05:26.710: %LWAPP-3-RADIUS_ERR: spam_radius.c:138 Could not send join reply, AP authorization failed; AP:
I don't know what could be wrong. The console of the AP tells me:
*Mar 1 00:00:52.717: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Mar 1 00:00:52.717: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:58.726: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Mar 1 00:00:58.726: LWAPP_CLIENT_ERROR_DEBUG: No more AP manager IP addresses remain.
*Mar 1 00:00:58.751: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
The AP gets the IP Address via DHCP successfully.
Sincerly
5 Replies 5
jeromehenry_2
Level 3
Level 3
Could you specify which AP model? Which AI address does it get from the DHCP server? Management IP or AP Manager IP?
Has this AP joined a controller before?
The model of the AP is 1131. The AP joined another Controller (WLC4404) before successfully.
I don't know what you mean with DHCP Managment IP oder AP Manager IP. Both IP's are in the same subnet. The AP DHCP Pool is in that subnet too. I use an external DHCP Server.
Is this a mesh AP? The only reference I can find to te "BOARD_DATA" message is with regards to when child mesh AP's try to join a controller.
Also - looks like you could have the AP Authorization List enabled, and that this AP is not in the list of authorized AP's.
This is usually a good article to review for troubleshooting:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
No, it is not a mesh ap.
How can I disable the AP Authorization List. I have no List AP's configured in this list. The list is empty.
I was now successfully. I made an entry in our radius server and disable all marks under security ap policy except SSC. Now the AP joins the wism.
