Problem with WLC 5508 Roaming with iPhone
armando.barrera
Community Member
First of all greetings to all in the community.
The problem I am running is in the roaming phones mainly iphone, which I have them in a SSID also serves to data connection of other devices which has the following security policy [WPA + WPA2] [Auth (802.1x )]
WLC: 7.0.98.0
iphone: V6.0 OS
jabber: v9.02.20078
For DCA parameters were configured channels 1,6 and 11. I'm testing with a floor where there are 2 APs and AP normal users are 10 to 13 connected devices, also reviewed in each AP channel where an AP is on channel 1 and the other is in the channel 6.
I was able to capture the following errors in the APs.
Exhibits some show on catches.
Appreciating your valuable help, I say goodbye
Jaffar Nassiry
Frequent Visitor
Frequent Visitor
Hi Armando,
Refrence this bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta91836
Also recommend upgrading your 5508s firmware
Leo Laohoo
[WPA + WPA2]
iPhones don't like choices.  You either run WPA or WPA2.  Don't try to run both and presume the iDevice can decide because they won't.
