Problem WLC with apfMsConnTask_4
jmanzur1683
Visitor
I have a Cisco WLC 5508, and it crashed, and this is the message of the crash:
"Analysis of Failure:
  Software was stopped by the reaper for the following reason:
     Reaper Reset: Task "apfMsConnTask_4" taking too much cpu: 100%  (user 18%, system 81%) while SW Watchdog is disabled"
Do you know what means this message?
Versio IOS:
7.0.98.0
George Stefanick
Hi Jorge,
I am not fimilar with that specific error message. But I do know, if you call TAC and tell them you are on 7.0.98.0 they will tell you to move to 7.0.220.0.
7.0.98.0 is a bit buggy.
Stephen Rodriguez
Basically, it is telling you that the Reaper task had to kill a process becuase it was taking up too much of the resources.  And it caused the box to crash.
But as George said, you'll want to upgrade to 7.0.220.0, as 98 is buggy.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
