Problema para Agregar AP-1562I-A-K9 a controladora Mobility Express
fkceres
Hola,
Tengo un problema tengo un Ap modelo AP-1562I-A-K9  que no me permite agregar a la controladora mobility express que tengo instalada en un AP2802I-A-K9 con una versión 8.10.130.0 marcándome los siguientes errores:
[*08/19/2020 18:06:15.2983] Stopped Radio 0
[*08/19/2020 18:06:15.3307] Stopped Radio 1
[*08/19/2020 18:06:15.3352] SYS-COND: Bringing down radio wifi0
[*08/19/2020 18:06:15.3352] SYS-COND: Bringing down radio wifi1
[*08/19/2020 18:06:15.3352] SYS-COND: AP is in critical condition
[*08/19/2020 18:06:15.6886] DOT11_CFG[0] Radio Mode is changed from Bridge to Bridge
[*08/19/2020 18:06:15.6893] DOT11_CFG[1] Radio Mode is changed from Bridge to Bridge
[*08/19/2020 18:06:16.4053] dtls_init: Use SUDI certificate
[*08/19/2020 18:06:16.4057]
[*08/19/2020 18:06:16.4057] CAPWAP State: Init
[*08/19/2020 18:06:16.4064]
[*08/19/2020 18:06:16.4064] PNP is not required, Starting CAPWAP discovery
[*08/19/2020 18:06:16.4066]
[*08/19/2020 18:06:16.4066] CAPWAP State: Discovery
[*08/19/2020 18:06:16.4073] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxxx.com
[*08/19/2020 18:06:16.4130] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*08/19/2020 18:06:16.4130] CAPWAP State: Discovery
[*08/19/2020 18:06:16.4147] Discovery Response from 10.248.180.251
[*08/19/2020 18:06:16.4247] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
[*08/19/2020 18:06:16.4247] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
[*08/19/2020 18:07:31.0000] can't find the Ip from discoveryRequest array
[*08/19/2020 18:07:31.0001]
[*08/19/2020 18:07:31.0001] CAPWAP State: DTLS Setup
[*08/19/2020 18:07:31.3737]
[*08/19/2020 18:07:31.3737] CAPWAP State: Join
[*08/19/2020 18:07:31.3752] Sending Join request to 10.248.180.251 through port 5272
[*08/19/2020 18:07:31.3785] Join Response from 10.248.180.251
[*08/19/2020 18:07:31.3786] AC rejected join request[10], try again later.
[*08/19/2020 18:07:31.4627] HW CAPWAP tunnel is ADDED
[*08/19/2020 18:07:31.4786]
[*08/19/2020 18:07:31.4786] CAPWAP State: Image Data
[*08/19/2020 18:07:31.5137] do PRECHECK, part2 is active part
[*08/19/2020 18:07:31.6594] Image Data Request sent to 10.248.180.251
[*08/19/2020 18:07:34.4179] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:37.2688] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:40.1196] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:42.9714] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:43.6538] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Image Data(10).
[*08/19/2020 18:07:45.8214] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:46.0890] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Image Data(10).
[*08/19/2020 18:07:48.6722] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/19/2020 18:07:48.6722] Max retransmission count exceeded, going back to DISCOVER mode.
[*08/19/2020 18:07:48.6728]
[*08/19/2020 18:07:48.6728] CAPWAP State: DTLS Teardown
[*08/19/2020 18:08:59.4296] do ABORT, part2 is active part
[*08/19/2020 18:08:59.5525]
[*08/19/2020 18:08:59.5525] CAPWAP State: Discovery
[*08/19/2020 18:08:59.5536] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxxxx.com
[*08/19/2020 18:08:59.5588] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*08/19/2020 18:08:59.5595] Discovery Response from 10.248.180.251
[*08/19/2020 18:08:59.5671] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
[*08/19/2020 18:08:59.5671] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
[*08/19/2020 18:09:09.0000] can't find the Ip from discoveryRequest array
Espero y me puedan ayudar.
Gracias
5 Replies 5
ajc
Level 7
Level 7
puedes accesar al AP y copiar el resultado del comando SHOW LOGGING?.
Hola,
Anexo el Show Logging, Gracias
AP780C.F02D.E120#show logging
System logging:
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.3781] Join Response from 10.248.180.251
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.3781] AC rejected join request[10], try again later.
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.4643] HW CAPWAP tunnel is ADDED
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.4816]
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.4816] CAPWAP State: Image Data
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.5167] do PRECHECK, part2 is active part
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.5663] UBIFS: background thread "ubifs_bgt0_0" started, PID 26050
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6017] UBIFS: mounted UBI device 0, volume 0, name "part1"
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6017] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6017] UBIFS: FS size: 65646592 bytes (62 MiB, 517 LEBs), journal size 8888320 bytes (8 MiB, 70 LEBs)
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6017] UBIFS: reserved for root: 0 bytes (0 KiB)
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6017] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 71355613-AF96-4582-979D-9DDCBCA73B29, small LPT model
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6699] UBIFS: un-mount UBI device 0, volume 0
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6699] UBIFS: background thread "ubifs_bgt0_0" stops
Aug 19 19:01:04 kernel: [*08/19/2020 19:01:04.6738] Image Data Request sent to 10.248.180.251
Aug 19 19:01:07 kernel: [*08/19/2020 19:01:07.4210] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:10 kernel: [*08/19/2020 19:01:10.2719] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:13 kernel: [*08/19/2020 19:01:13.1228] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:15 kernel: [*08/19/2020 19:01:15.9737] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:18 kernel: [*08/19/2020 19:01:18.8245] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:21 kernel: [*08/19/2020 19:01:21.6755] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:21 kernel: [*08/19/2020 19:01:21.6755] Max retransmission count exceeded, going back to DISCOVER mode.
Aug 19 19:01:21 kernel: [*08/19/2020 19:01:21.6760]
Aug 19 19:01:21 kernel: [*08/19/2020 19:01:21.6760] CAPWAP State: DTLS Teardown
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.4253] do ABORT, part2 is active part
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5479]
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5479] CAPWAP State: Discovery
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5501] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5502] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxxxx.com
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5552] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5576] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5577] Discovery Response from 10.248.180.251
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5655] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5655] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5658] Discovery Response from 10.248.180.251
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5733] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5733] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5734] Discovery Response from 10.248.180.251
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5811] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:01:27 kernel: [*08/19/2020 19:01:27.5811] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:01:32 kernel: [*08/19/2020 19:01:32.9270] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.0000]
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.0000] CAPWAP State: DTLS Setup
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.3720]
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.3720] CAPWAP State: Join
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.3743] Sending Join request to 10.248.180.251 through port 5256
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.3775] Join Response from 10.248.180.251
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.3776] AC rejected join request[10], try again later.
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.4673] HW CAPWAP tunnel is ADDED
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.4841]
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.4841] CAPWAP State: Image Data
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.5228] do PRECHECK, part2 is active part
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.5712] UBIFS: background thread "ubifs_bgt0_0" started, PID 26303
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6078] UBIFS: mounted UBI device 0, volume 0, name "part1"
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6078] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6078] UBIFS: FS size: 65646592 bytes (62 MiB, 517 LEBs), journal size 8888320 bytes (8 MiB, 70 LEBs)
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6078] UBIFS: reserved for root: 0 bytes (0 KiB)
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6078] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 71355613-AF96-4582-979D-9DDCBCA73B29, small LPT model
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6497] UBIFS: un-mount UBI device 0, volume 0
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6497] UBIFS: background thread "ubifs_bgt0_0" stops
Aug 19 19:01:37 kernel: [*08/19/2020 19:01:37.6539] Image Data Request sent to 10.248.180.251
Aug 19 19:01:40 kernel: [*08/19/2020 19:01:40.4210] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:43 kernel: [*08/19/2020 19:01:43.2719] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:46 kernel: [*08/19/2020 19:01:46.1228] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:48 kernel: [*08/19/2020 19:01:48.9737] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:51 kernel: [*08/19/2020 19:01:51.8256] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:54 kernel: [*08/19/2020 19:01:54.6754] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:01:54 kernel: [*08/19/2020 19:01:54.6754] Max retransmission count exceeded, going back to DISCOVER mode.
Aug 19 19:01:54 kernel: [*08/19/2020 19:01:54.6760]
Aug 19 19:01:54 kernel: [*08/19/2020 19:01:54.6760] CAPWAP State: DTLS Teardown
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.4248] do ABORT, part2 is active part
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5485]
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5485] CAPWAP State: Discovery
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5513] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5515] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxxxx.com
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5568] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5583] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5584] Discovery Response from 10.248.180.251
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5671] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5671] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5674] Discovery Response from 10.248.180.251
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5757] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5757] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5758] Discovery Response from 10.248.180.251
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5831] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:00 kernel: [*08/19/2020 19:02:00.5831] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.0000]
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.0000] CAPWAP State: DTLS Setup
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.3742]
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.3743] CAPWAP State: Join
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.3768] Sending Join request to 10.248.180.251 through port 5256
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.3799] Join Response from 10.248.180.251
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.3800] AC rejected join request[10], try again later.
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.4656] HW CAPWAP tunnel is ADDED
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.4810]
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.4810] CAPWAP State: Image Data
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.5172] do PRECHECK, part2 is active part
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.5648] UBIFS: background thread "ubifs_bgt0_0" started, PID 26580
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6001] UBIFS: mounted UBI device 0, volume 0, name "part1"
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6001] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6001] UBIFS: FS size: 65646592 bytes (62 MiB, 517 LEBs), journal size 8888320 bytes (8 MiB, 70 LEBs)
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6001] UBIFS: reserved for root: 0 bytes (0 KiB)
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6001] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 71355613-AF96-4582-979D-9DDCBCA73B29, small LPT model
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6695] UBIFS: un-mount UBI device 0, volume 0
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6695] UBIFS: background thread "ubifs_bgt0_0" stops
Aug 19 19:02:10 kernel: [*08/19/2020 19:02:10.6735] Image Data Request sent to 10.248.180.251
Aug 19 19:02:13 kernel: [*08/19/2020 19:02:13.4243] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:16 kernel: [*08/19/2020 19:02:16.2751] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:19 kernel: [*08/19/2020 19:02:19.1260] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:21 kernel: [*08/19/2020 19:02:21.9768] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:24 kernel: [*08/19/2020 19:02:24.8277] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:27 kernel: [*08/19/2020 19:02:27.6786] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:27 kernel: [*08/19/2020 19:02:27.6786] Max retransmission count exceeded, going back to DISCOVER mode.
Aug 19 19:02:27 kernel: [*08/19/2020 19:02:27.6792]
Aug 19 19:02:27 kernel: [*08/19/2020 19:02:27.6792] CAPWAP State: DTLS Teardown
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.4287] do ABORT, part2 is active part
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5529]
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5529] CAPWAP State: Discovery
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5555] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5557] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxxx.com
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5619] Discovery Request sent to 10.248.180.251, discovery type STATIC_CONFIG(1)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5630] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5631] Discovery Response from 10.248.180.251
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5721] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5722] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5724] Discovery Response from 10.248.180.251
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5810] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5810] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5811] Discovery Response from 10.248.180.251
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5887] TLV-DEC-ERR: cannot process TLV for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661/0)
Aug 19 19:02:33 kernel: [*08/19/2020 19:02:33.5887] TLV-DEC-ERR: No CB for TLV_EXPIRE_MIC_TYPE_PAYLOAD(661)
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.0000]
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.0000] CAPWAP State: DTLS Setup
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.3727]
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.3727] CAPWAP State: Join
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.3753] Sending Join request to 10.248.180.251 through port 5256
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.3786] Join Response from 10.248.180.251
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.3786] AC rejected join request[10], try again later.
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.4665] HW CAPWAP tunnel is ADDED
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.4835]
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.4835] CAPWAP State: Image Data
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.5183] do PRECHECK, part2 is active part
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.5668] UBIFS: background thread "ubifs_bgt0_0" started, PID 26832
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6020] UBIFS: mounted UBI device 0, volume 0, name "part1"
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6020] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6020] UBIFS: FS size: 65646592 bytes (62 MiB, 517 LEBs), journal size 8888320 bytes (8 MiB, 70 LEBs)
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6020] UBIFS: reserved for root: 0 bytes (0 KiB)
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6020] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 71355613-AF96-4582-979D-9DDCBCA73B29, small LPT model
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6459] UBIFS: un-mount UBI device 0, volume 0
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6460] UBIFS: background thread "ubifs_bgt0_0" stops
Aug 19 19:02:43 kernel: [*08/19/2020 19:02:43.6501] Image Data Request sent to 10.248.180.251
Aug 19 19:02:46 kernel: [*08/19/2020 19:02:46.4210] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:49 kernel: [*08/19/2020 19:02:49.2719] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:52 kernel: [*08/19/2020 19:02:52.1258] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:52 kernel: [*08/19/2020 19:02:52.1259]
Aug 19 19:02:53 kernel: [*08/19/2020 19:02:53.7597] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Image Data(10).
Aug 19 19:02:54 kernel: [*08/19/2020 19:02:54.9736] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:02:57 kernel: [*08/19/2020 19:02:57.8244] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:03:00 kernel: [*08/19/2020 19:03:00.6763] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
Aug 19 19:03:00 kernel: [*08/19/2020 19:03:00.6764]
Aug 19 19:03:00 kernel: [*08/19/2020 19:03:00.6764] Max retransmission count exceeded, going back to DISCOVER mode.
Aug 19 19:03:00 kernel: [*08/19/2020 19:03:00.6769]
Aug 19 19:03:00 kernel: [*08/19/2020 19:03:00.6769] CAPWAP State: DTLS Teardown
AP780C.F02D.E120#
Encontre 2 opciones similares a tu problema. No estoy muy familiarizado con mobility express
Cambiar la version de software
https://community.cisco.com/t5/wireless-and-mobility/1852i-unable-to-join-mobility-express-controller/td-p/3020126
O
Agregar el AP MAC address to the WLC Security.
https://community.cisco.com/t5/wireless-and-mobility/air-ap1562e-n-k9-won-t-join-a-2504-wlc/td-p/3848378
For the external AP's, the AP mac address must be explicitly added in the WLC security to the AP policies.
revisa que modo de operacion que requiere tu access point, si requieres bridge mode o local mode. No se como lo tienes configurado, tendrias que validar si necesitas cambiarlo a local mode.
