Problems connecting clients
slandeira
Level 3
Level 3
I have two controllers Cisco 4402 with Software Version 3.2.171.6.
The network have authentication WPA, data encryption TKIP and PEAP authentication.
With Windows XP customers I have no problem, but customers with Windows Vista gives an error message like that could see attached: "network settings saved in this PC does not match the requirements of the network"
What may be happening?
Thank you
Scott Fella
Make sure on the Vista clients that is is indeed WPA and tkip configured and not WPA with AES. Also verify that PEAP and not smart card is configured.
DO you get an error on your radius server since you are using PEAP or on your WLC?
-Scott
