Problems in accepting configuration
pferraz
Level 3
Level 3
Hi.
I'm having problems chanving the configuration of an Cisco 350 Series Access Point running firmware 12.00T.
I haven´t got User Manager enabled, so i guess i should be able to change the fields. The problem is that though I'm able to change every field, next when the browser/console does a refresh, the old configuration still appears!
Any thoughts?
Thanks in advance!
5 Replies 5
kmarrero
Level 8
Level 8
When you make any changes to the configuration via the web interface you need to click the "apply" button. The AP is not set up to do an automatic update when configuring it through the browser. If you have clicked the "apply" button and the AP still is not saving the changes, then you will need to try and set the unit back to the factory settings and starting over.
To get the unit back to factory settings you need to console into the AP. Once you are consoled into the device you will power the AP off and then back on. Let the AP go through its boot up process and once it stops on a command prompt type ":resetall" and hit enter. It should ask you if you are sure that you want to set it back to default and type yes. The device should restart itself and be back to factory defaults. Keep in mind that it will as well have it's default IP address of 10.0.0.1.
Do you know if there is any kind of problem or pre-requisites with changing the SNMP string?
Strangely enough, I've now detected that I'm able to change the other fields but not the SNMP string!
Thanks again for your help
jimmy.seah
Level 2
Level 2
Could it just be that your brower is loading from cache??? Try to 'OK' or 'APPLY' each time you change a field and hold 'Ctrl' then refresh the screen.
No, because the same problem happens with the console.
thanks
Try deleting the user created when you originally entered the SNMP Admin Community. I just ran into this and that fixed my problem.
