Problems in the first authentication
slandeira
Level 3
Level 3
I have installed a Controller 4402 with version 4.0.217.0, APs 1010, with server of authentication RADIUS of Microsoft (IAS), using 802.1x with PEAP and MS-CHAP-v2. I have a problem in the first authentication, it is not only that he is slow, is that it asks for ?n? times that you introduce user and password. Although finally gets to connect and works fine, we cannot do this with each client ?n? times? In addition, if user changes password, which is habitual since by company policy it commits to the change of password every 6 months, in some cases is no form of which it returns to authenticate. We have proven to even erase the key of the registry but the result is the same.
You can help me?
Thank you very much
j.metzger
Community Member
Have you tried to disable the aggressive load balancing?
The aggressive Load Balancing is Disabled.
Ok!! It was not sure! The agresive Load Balaning was enable. The problem has been solved, changing enable. Thank you very much.
