Problems, WebAuth certificate on WLC5508
MarcP829
Hi there,
trying to update the cert forWeb Auth on WLC5508, Firmware 8.0.152.0
Started using OpenSSL 0.9.8 for creating a CSR.
req −new −newkey rsa:2048 −nodes −keyout mykey.pem −out myreq.pem
Worked well so far. As we wrote in some posts, we used a Password, but tried it without as well, same problems later.
After that, we ordered a certificat from Comodo and received back a .ca-bundled and a .crt.
Put all together, "CSR", "bundled" and .crt
So we started the upload on WLC5508 and following output came on ssh:
(Cisco Controller) >debug transfer all enable
(Cisco Controller) >*emWeb: May 08 10:36:03.310:
Requesting for login page (login.html)
*TransferTask: May 08 10:50:15.795: Memory overcommit policy changed from 0 to 1
*TransferTask: May 08 10:50:15.795: RESULT_STRING: TFTP Webauth cert transfer starting.
*TransferTask: May 08 10:50:15.795: RESULT_CODE:1
*TransferTask: May 08 10:50:19.799: Locking tftp semaphore, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:50:19.883: Semaphore locked, now unlocking, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:50:19.883: Semaphore successfully unlocked, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:50:19.883: TFTP: Binding to remote=10.1.22.21
*TransferTask: May 08 10:50:19.897: TFP End: 6434 bytes transferred (0 retransmitted packets)
*TransferTask: May 08 10:50:19.897: tftp rc=0, pHost=10.1.22.21 pFilename=/GWeb.pem
pLocalFilename=cert.p12
*TransferTask: May 08 10:50:19.897: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: May 08 10:50:19.897: RESULT_CODE:13
*TransferTask: May 08 10:50:23.899: Adding cert (6382 bytes) with certificate key password.
*TransferTask: May 08 10:50:23.907: RESULT_STRING: Error installing certificate.
*TransferTask: May 08 10:50:23.907: RESULT_CODE:12
*TransferTask: May 08 10:50:23.907: Memory overcommit policy restored from 1 to 0
As this wasn´t clear for us, what is causing the problem, we tried another debug command:
(Cisco Controller) >debug pm pki enable
(Cisco Controller) >*TransferTask: May 08 10:53:07.639: Memory overcommit policy changed from 0 to 1
*TransferTask: May 08 10:53:07.639: RESULT_STRING: TFTP Webauth cert transfer starting.
*TransferTask: May 08 10:53:07.639: RESULT_CODE:1
*emWeb: May 08 10:53:07.641: sshpmGetIdCertIndex: called to lookup cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.641: sshpmGetIdCertIndex: found match in row 4
*emWeb: May 08 10:53:07.641: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.641: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.645: sshpmGetSerialNumber: serial number: 3180585505
*emWeb: May 08 10:53:07.645: sshpmGetSerialNumber: SerialNumberStr return value: >3180585505<
*emWeb: May 08 10:53:07.645: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.645: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.648: sshpmGetValidToDate: NotAfter: 2020 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:07.648: sshpmGetValidToDate: NotAfter return value: >2020 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:07.648: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.648: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.648: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.648: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.649: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.652: sshpmGetValidFromDate: NotBefore: 2010 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:07.652: sshpmGetValidFromDate: NotBefore return value: >2010 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:07.652: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.652: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.656: sshpmGetSubjectName: SubjectName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:07.656: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.656: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.660: sshpmGetIssuerName: calling DumpNameToBuffer()
*emWeb: May 08 10:53:07.660: sshpmGetIssuerName: IssuerName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:07.660: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.660: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:07.660: SHA1 = 3b:a2:1d:c1:fc:f5:a9:b3:1a:ab:03:4e:c0:48:ae:9a:7a:2d:ea:c6
*emWeb: May 08 10:53:07.661: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:07.661: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:07.661: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:07.661: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:07.661: MD5 = 8a:3a:5e:10:bc:c1:3f:49:32:19:62:75:46:fa:e4:06
*emWeb: May 08 10:53:10.824: sshpmGetIdCertIndex: called to lookup cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.824: sshpmGetIdCertIndex: found match in row 4
*emWeb: May 08 10:53:10.824: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.824: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.827: sshpmGetSerialNumber: serial number: 3180585505
*emWeb: May 08 10:53:10.827: sshpmGetSerialNumber: SerialNumberStr return value: >3180585505<
*emWeb: May 08 10:53:10.828: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.828: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.831: sshpmGetValidToDate: NotAfter: 2020 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:10.831: sshpmGetValidToDate: NotAfter return value: >2020 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:10.831: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.831: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.834: sshpmGetValidFromDate: NotBefore: 2010 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:10.834: sshpmGetValidFromDate: NotBefore return value: >2010 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:10.834: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.834: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.835: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.839: sshpmGetSubjectName: SubjectName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:10.839: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.839: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.842: sshpmGetIssuerName: calling DumpNameToBuffer()
*emWeb: May 08 10:53:10.842: sshpmGetIssuerName: IssuerName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:10.843: SHA1 = 3b:a2:1d:c1:fc:f5:a9:b3:1a:ab:03:4e:c0:48:ae:9a:7a:2d:ea:c6
*emWeb: May 08 10:53:10.843: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:10.843: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:10.843: MD5 = 8a:3a:5e:10:bc:c1:3f:49:32:19:62:75:46:fa:e4:06
*TransferTask: May 08 10:53:11.643: Locking tftp semaphore, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:53:11.727: Semaphore locked, now unlocking, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:53:11.727: Semaphore successfully unlocked, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:53:11.741: TFTP: Binding to remote=10.1.22.21
*TransferTask: May 08 10:53:11.760: TFP End: 6434 bytes transferred (0 retransmitted packets)
*TransferTask: May 08 10:53:11.760: tftp rc=0, pHost=10.1.22.21 pFilename=/GWeb.pem
*TransferTask: May 08 10:53:11.760: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: May 08 10:53:11.760: RESULT_CODE:13
*emWeb: May 08 10:53:13.997: sshpmGetIdCertIndex: called to lookup cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:13.998: sshpmGetIdCertIndex: found match in row 4
*emWeb: May 08 10:53:13.998: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:13.998: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:13.998: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:13.998: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:13.999: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.002: sshpmGetSerialNumber: serial number: 3180585505
*emWeb: May 08 10:53:14.002: sshpmGetSerialNumber: SerialNumberStr return value: >3180585505<
*emWeb: May 08 10:53:14.002: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.002: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.005: sshpmGetValidToDate: NotAfter: 2020 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:14.006: sshpmGetValidToDate: NotAfter return value: >2020 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:14.006: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.006: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.009: sshpmGetValidFromDate: NotBefore: 2010 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:14.009: sshpmGetValidFromDate: NotBefore return value: >2010 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:14.009: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.009: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.010: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.010: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.010: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.013: sshpmGetSubjectName: SubjectName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:14.014: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.014: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.017: sshpmGetIssuerName: calling DumpNameToBuffer()
*emWeb: May 08 10:53:14.017: sshpmGetIssuerName: IssuerName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:14.017: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.017: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.018: SHA1 = 3b:a2:1d:c1:fc:f5:a9:b3:1a:ab:03:4e:c0:48:ae:9a:7a:2d:ea:c6
*emWeb: May 08 10:53:14.018: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:14.018: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:14.018: MD5 = 8a:3a:5e:10:bc:c1:3f:49:32:19:62:75:46:fa:e4:06
*TransferTask: May 08 10:53:15.763: Adding cert (6382 bytes) with certificate key password.
*TransferTask: May 08 10:53:15.770: sshpmCheckCert: Verification return code: 0
*TransferTask: May 08 10:53:15.770: Verification result text: unable to get issuer certificate
*TransferTask: May 08 10:53:15.770: Error at 2 depth: unable to get issuer certificate
*TransferTask: May 08 10:53:15.771: sshpmAddWebauthCert: Error decoding certificate, Deleting it.
*TransferTask: May 08 10:53:15.771: RESULT_STRING: Error installing certificate.
*TransferTask: May 08 10:53:15.771: RESULT_CODE:12
*TransferTask: May 08 10:53:15.772: Memory overcommit policy restored from 1 to 0
*emWeb: May 08 10:53:17.116: sshpmGetIdCertIndex: called to lookup cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.116: sshpmGetIdCertIndex: found match in row 4
*emWeb: May 08 10:53:17.116: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.116: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.120: sshpmGetSerialNumber: serial number: 3180585505
*emWeb: May 08 10:53:17.120: sshpmGetSerialNumber: SerialNumberStr return value: >3180585505<
*emWeb: May 08 10:53:17.120: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.120: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.123: sshpmGetValidToDate: NotAfter: 2020 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:17.123: sshpmGetValidToDate: NotAfter return value: >2020 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:17.123: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.123: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.124: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.124: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.126: sshpmGetValidFromDate: NotBefore: 2010 Sep 19th, 00:00:01 GMT
*emWeb: May 08 10:53:17.127: sshpmGetValidFromDate: NotBefore return value: >2010 Sep 19th, 00:00:01 GMT<
*emWeb: May 08 10:53:17.127: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.127: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetSubjectName: SubjectName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:17.131: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.131: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.135: sshpmGetIssuerName: calling DumpNameToBuffer()
*emWeb: May 08 10:53:17.135: sshpmGetIssuerName: IssuerName: >C=US, O=Cisco Systems Inc., OU=DeviceSSL (WebAuth), CN=1.1.1.1<
*emWeb: May 08 10:53:17.135: sshpmGetCID: called to evaluate <bsnSslWebauthCert>
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 7, CA cert >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 6, CA cert >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 5, CA cert >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 4, ID cert >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: called to get cert for CID 15b5871e
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 7, certname >cscoMfgSha2CaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 6, certname >cscoRootSha2CaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 5, certname >cscoDefaultMfgCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 4, certname >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 3, certname >bsnDefaultBuildCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
*emWeb: May 08 10:53:17.135: SHA1 = 3b:a2:1d:c1:fc:f5:a9:b3:1a:ab:03:4e:c0:48:ae:9a:7a:2d:ea:c6
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
*emWeb: May 08 10:53:17.135: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.136: sshpmGetCertFromCID: comparing to row 2, certname >bsnDefaultCaCert<
*emWeb: May 08 10:53:17.136: sshpmGetCertFromCID: comparing to row 1, certname >bsnDefaultRootCaCert<
*emWeb: May 08 10:53:17.136: sshpmGetCertFromCID: comparing to row 0, certname >bsnOldDefaultCaCert<
*emWeb: May 08 10:53:17.136: sshpmGetCertFromCID: comparing to row 4, certname >bsnSslWebauthCert<
Unfortunately, we still don´t know whats the problem... Can someone please help us on that? Tried it for hours now and not beeing able to fix it.
Using diverse online recommendations didn´t help so far.
Sandeep Choudhary
I got the same issue with WLC version 8.0.152.0. Then i upgraded to 8.3.143.0 and it worked.
Dont forget to rate helpful posts
Hm, this won´t work for me, as we use too old AccessPoints...
AIR-CAP3502I-E-K9
AIR-LAP1131G-E-K9
These are only supported to the 8.0.152.0 Firmware :(
Have you tried following these instructions?
https://support.comodo.com/index.php?/Knowledgebase/Article/View/778/37/certificate-installation-cisco-wlan-4400
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
have you also confirmed the date/ time on the WLC is correct.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
