Problems with AP AUthentication RADIUS LOCAL
rmacapital
Frequent Visitor
Frequent Visitor
i have a probleme with my AP for authentification radius local for systms window and linux .
scenario :
vlan 1 192.168.1.206  ( @ip radius)
vlan 6 192.168.40.1
vlan 11 192.168.11.1
config file is :
DIGITAL_VIRGO_AP_01#sh
DIGITAL_VIRGO_AP_01#show run
DIGITAL_VIRGO_AP_01#show running-config
Building configuration...
Current configuration : 5001 bytes
! Last configuration change at 15:21:58 UTC Mon Mar 1 1993
version 15.2
no service pad
service password-encryption
hostname DIGITAL_VIRGO_AP_01
logging rate-limit console 9
enable secret 5 $1$axdM$RRb04djt0jSKc1ohhFBPF/
aaa new-model
aaa group server radius rad_eap
 server 192.168.1.206 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap2
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip routing
no ip cef
dot11 syslog
dot11 vlan-name management vlan 6
dot11 ssid DIGITALVIRGO_PRIVE
   vlan 11
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 08254549000D041B32595C557F
dot11 ssid DIGITAL_GUEST
   vlan 6
   authentication open eap eap_methods2
   authentication network-eap eap_methods2
   mbssid guest-mode
username Cisco password 7 14341B180F0B
username root privilege 15 password 7 0737055A4A5A4B1F44
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers tkip
 encryption vlan 10 mode ciphers tkip
 encryption vlan 12 mode ciphers tkip
 encryption vlan 11 mode ciphers tkip
 encryption vlan 6 mode ciphers aes-ccm
 ssid DIGITAL_GUEST
 antenna gain 0
 stbc
 beamform ofdm
 mbssid
 station-role root access-point fallback shutdown
 l2-filter bridge-group-acl
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.6
 encapsulation dot1Q 6
 no ip route-cache
 bridge-group 6
 bridge-group 6 subscriber-loop-control
 bridge-group 6 spanning-disabled
 bridge-group 6 block-unknown-source
 no bridge-group 6 source-learning
 no bridge-group 6 unicast-flooding
interface Dot11Radio0.11
 encapsulation dot1Q 11
 no ip route-cache
 bridge-group 11
 bridge-group 11 subscriber-loop-control
 bridge-group 11 spanning-disabled
 bridge-group 11 block-unknown-source
 no bridge-group 11 source-learning
 no bridge-group 11 unicast-flooding
interface Dot11Radio0.12
 encapsulation dot1Q 12
 no ip route-cache
 bridge-group 12
 bridge-group 12 subscriber-loop-control
 bridge-group 12 spanning-disabled
 bridge-group 12 block-unknown-source
 no bridge-group 12 source-learning
 no bridge-group 12 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 antenna gain 0
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.6
 no ip route-cache
 bridge-group 6
interface GigabitEthernet0.11
 no ip route-cache
 bridge-group 11
interface GigabitEthernet0.12
 no ip route-cache
 bridge-group 12
interface BVI1
 ip address 192.168.10.100 255.255.255.0 secondary
 ip address 192.168.1.206 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 701 deny   6876.4fff.a42c   0000.0000.0000
radius-server local
  nas 192.168.1.206 key 7 0822455D0A16
  user digital nthash 7 03517853565F071D1D284A26324A5D2920787E7078171176365045505073007901
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.206 auth-port 1812 acct-port 1813 key 7 060506324F41
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
 transport input all
end
- See more at: https://supportforums.cisco.com/discussion/12513601/probleme-radius-local-ap#sthash.beL6D2Uu.dpuf
0 Replies 0
