problems with reauthentication (wism & acs v3)
vbuchholz
i have a wism installed in a c6509. everything seems to work fine. in the wlan options i have configured allow aaa override, so the acs ver3 can override the session timeout from the controller, which is 1800. but when the timeout comes the client will not reauthenticate but disconnect. has anybody similar problems with this configuration?
amritpatek
Level 6
Level 6
Is this for the guest client?. Because, in guest clients, there are two kinds of timeout values. One is the guest account ;life time and the guest WLAN timeout. The smaller of these two will be selected actually.
So, if guest account timeout is smaller, then the account will get deactivated without being reauthenticated.
