Problems with wireless Hwic access point.
artraffa1
Community Member
When I configure multiple ssids they seem to work fine until I add any sort of security.
When a add a simple WEP key my data vlan works fine, I can get to all the interfaces and networks, but my voice vlan does not it does get an IP from the dhcp server but I cannot ping any networks inside the router or from the router to the Voice Vlan.
I think that I'm following the rules correctly
Can any one provide any advice on how to fix my problem?
Attached is my basic config and the only changes I make are the following:
encryption vlan 20 key 1 size 128bit xxx transmit-key
encryption vlan 20 mode wep mandatory
encryption vlan 100 mode wep mandatory
Richard Atkin
Level 10
Level 10
I've never used a HWIC AP before, but I think you might have the wrong end of the stick on a couple of things.
Take a look at the following config and see what you think. This uses VLAN50 for the AP Management Address and VLANs 100 & 200 for client traffic.
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 200 key 1 size 40bit 7 <> transmit-key
encryption vlan 200 mode wep mandatory
encryption vlan 100 key 1 size 40bit 7 <> transmit-key
ssid BMS_network
vlan 200
authentication open
ssid data_network
vlan 100
authentication open
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
interface Dot11Radio0.50
encapsulation dot1Q 50 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface Dot11Radio0.200
encapsulation dot1Q 200
no ip route-cache
bridge-group 200
bridge-group 200 subscriber-loop-control
bridge-group 200 block-unknown-source
no bridge-group 200 source-learning
no bridge-group 200 unicast-flooding
bridge-group 200 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 100 key 2 size 40bit 7 <> transmit-key
ssid BMS_network
vlan 200
authentication open
ssid data_network
vlan 100
authentication open
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1.50
no ip route-cache
bridge-group 1
interface Dot11Radio1.100
no ip route-cache
bridge-group 100
interface Dot11Radio1.200
no ip route-cache
bridge-group 200
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.50
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
interface FastEthernet0.100
no ip route-cache
bridge-group 100
interface FastEthernet0.200
no ip route-cache
bridge-group 200
interface BVI1
ip address 192.168.50.9 255.255.255.0
no ip route-cache
ip default-gateway 192.168.50.254
bridge 1 route ip
I have not got the chance to review and implement your suggestion because I for some reason utilized WPA instead of WEP and every thing seems to work fine with WPA. That was the only thing I changed in my config. When i get the chance I'll to try WEP becuase it should of worked as well.
