Programmatically determine firmware version of Wireless adapter
Adeyemi99
Device: 350 Series PCMCIA.
Can run Aironet Client Utility and get Firmware version from Status page. Need to be able to do this remotely on many clients. Help greatly appreciated.
fmeetz
Level 4
Level 4
Could you please elaborate? Do you intend to get the status of all clients using ACU at the same time ?
I need to be able to run a bit of code on a PC (the app will be placed on the PC wirelessly but will then run on the PC) and return the version of the firmware that is in use on that PC's aironet wireless adapter. If I run the Aironet Client Utility and press the Status option it shows it but I need to be able to get at it programmatically.
