PSPF Feature in WLAN Controller
vramanaiah
Level 3
Level 3
Does any one know how to enable PSPF in WLAN controller? Is it supported?
vramanaiah
Level 3
Level 3
Found out this is called Peer to Peer Block mode and is availble under controller configuration screen..!
it would be interessing if the pspf feature there only works per AP base or for the whole controller!!
anybody know this?
or atleast at the SSID level? I mean only for certain SSIDs but not for others..?
This peeer to peer blocking mode seem to restrict all SSIDs and APs.. 😞
