PSRT or SNT contract associated with Cisco Prime running over VM
Muhammed Adnan
Level 4
Level 4
Hello Experts,
I need to run Cisco Prime over VM. Need to comprehend:
a) Part number to be considered in CCW.
b) The support part number that should be added. For the Prime running over VM, I believe the support involved covers only the TAC cases.
RichardAtkin
Level 3
Level 3
Prime is a whole bunch of part codes... see here;
https://www.cisco.com/c/dam/en/us/products/collateral/cloud-systems-management/prime-infrastructure/presentation-c97-735996.pdf
If you're building this in CCW, it should add support for you automatically based on your account settings.
