Question About the Cisco Wireless Controller 5508
laravente
Community Member
I have been digging around in the gui and the cli to find a way to increase bandwidth for our staff (production) wifi vs. public. There are settings in the gui for each 802.11a/b/g/n where you can set mandatory and supported data rates. There are also QoS settings in Wireless that you can set between background, video, voice, and best effort roles (bronze, gold, platinum, and silver). My question is what is the best option to use in this situation? Obviously, we want more bandwidth to be used in our production environment.
Mark Elsen
 - The following document is a target https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/quality_of_service.html  . since 8.5(.x) is the last release applicable for the 5508. Normally the defaults will be good and or limitations depend on the controller model , unless you need to differentiate between vlans for different categories of traffic (as you mention).
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
 Any change on the radios can benefit both (production and public) but not only one. It is advisable to keep lower speed disable.
Mandatory as 12  and disable those below that.
  The QoS helps but is not something that will cause huge difference on the client experience.  What can have most impact is configure the Bandwith on the WLAN or per user, both possible.
Leo Laohoo
"more bandwidth" will depend in many factors, such as:
  1. What is the link speed between the AP and the switch?
  2. What is the link speed of the LAN and WAN?
  3. What is the model of the APs?
  4. What radio (or band) are the people complaining predominantly on?
  5. Are there any link errors between the AP and the switch, the backbone, the WLC?
