question about wireless adapter
admin_2
Level 7
Level 7
question:
A PCM352 client adapter will not achieve the same distance from an access point as a PCI352 adapterwhen using their default antenna configurations.
A right
B wrong
Because PCM352 have Integrated diversity dipoles and PCI352
have removable 2.2 dBi Dipole antenna,I don't konw the both if have the same distance
thanks a lot
Not applicable
I think the statement is wrong. I think they are the similar and so they should achieve the same distance. They have the same hardware but it is just the connectors that are different.
