06-12-2015 12:02 AM - edited 07-05-2021 03:23 AM
I have cisco access point "AIR-OEAP602I-E-K9" model and using in standalone mode .
How many active user support for this model at the same time?
Thank you.
Solved! Go to Solution.
06-16-2015 06:13 PM
This model can using without wlc? or Can I using in autonomous mode?
NO, this model only work with WLC (virtual or physical)
Rasika
*** Pls rate all useful responses ***
06-17-2015 02:23 AM
Cisco Aironet 600 OfficeExtend Series Access Points
06-12-2015 07:28 AM
https://supportforums.cisco.com/discussion/11278316/aironet-600-series-users-limitation
06-16-2015 06:07 PM
Hi Saurav Lodh,
Thank you very much.
06-16-2015 06:13 PM
Rasika
06-17-2015 02:23 AM
