Question on Cisco 340 - 802.11 adaptor
sm176811
I am using Cisco Aironet 340 client pcmcia adapter to connect to the 802.11b network. Now I am developing
an application which is required to query the network card and determine the BSSID List.
Microsoft webiste-defines that NDIS 5.1 has support for this information to be extracted using the OID:
OID_802_11_BSSID_LIST. However, when I send this to the NDIS driver, it returns an error 'ERROR_GEN_FAILURE'
(error no: 31).
Is the NDIS driver downloadable from the cisco website NDIS 5.1 compliant? Does it support the full
ranage of 802.11 OIDs defined by NDIS 5.1? Suprisingly, OID_802_11_RSSI which is also an OID in NDIS
5.1 works prefectly fine.
Does anyone know what the problem is. Whether it is the NDIS driver which is not compiant with NDIS
5.1 or whether I am making some mistakes.
Your help would be appreciated. BTW I am running this on a Windows 2K machine.
beth-martin
Level 5
Level 5
My guess it the driver is not 5.1 compliant. The syntax looks okay. Cisco might take an enhancement request through the TAC for you.
