Questions about default AP group
marioderosa2008
Level 7
Level 7
Hi all,
i am trying to understand whether it is possible to have newly provisioned AP's boot up with NO SSID's assigned to them by default.
As i understand it, all APs & the first 16 SSIDs all join the default group.
This is a pain as it means that we will have to have an AP properly physically installed before we are able to join it to a controller. We do not want AP's on our workbenches having live clients associated to them.
Does anyone know if this is possible?
thanks
Mario
Rasika Nayanajith
You could do this by using WLAN ID > 16 when defining your WLANs. In this way those won't advertise in default AP group.
Rasika
**** Please rate all useful responses ****
Rasika Nayanajith
Rasika
is there any way i can change the ID without deleting the SSID and creating it again from scratch?
can i do this via the CLI?
thanks
Mario
No, you cannot change the WLAN ID without deleting & creating it again.
If you are using default settings (ie broadcast SSID, WPA2/AES-802.1x, QoS profile-Silver, WMM-allow, CHd-enable,P2P-disabled) you can simply use following CLI context to do that (assuming WLAN ID 1 to be deleted & recreated as ID 17)
config wlan delete 1
config wlan create 17 ABC ABC
config wlan interface 17
config wlan enable 17
If any other features configured for this WLAN then you need to enable them via GUI or CLI. Below post should help you to understand more CLI commands to do this.
http://mrncciew.com/2013/05/16/wlan-config-via-cli-part-1/
Rasika
**** Pls rate all useful responses ****
