Questions On new Wireless Installation
Hello!
Multiple 2600 access point join the WLC.
Clients connecting through different APs get their addressing information from an external DHCP server.
Laptops connecting via fastethernet also get their configuration from DHCP.
Problems:
(1). I can access the web interface of the WLC from a laptop connected to fastethernet but the moment I connect the same laptop through Wifi (disconnecting fastethernet) the web connection fails even when ping goes successful. What could be the problem?
(2). DHCP server is programed to lease IP addresses, give masks, default gateway address and DNS address. This works well with the wired laptop but as for wifi clients, DNS information is not provided. What could be the cause and possible remedy?
I wait for your response.
Thanks in advance
George Stefanick
Hi Kelvin,
1) Do you have management over wireless enabled ? Go->Management->Management via wireless (left side) .. Is it check boxed?
2) Is DNS set up in the scope for wireless ? Double check
I like how you presented your question and topology. This was like a test question ! LOL
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Hi Kevin,
I am sure George's response is the answer to your query.
I also like the way you present the question...
Rasika
