How to check if WLC is configured for DHCP or not
mahesh18
Level 6
Level 6
                   Hi Everyone,
Is there any command CLI  that can tell me if users are getting IP from WLC  or not?
Mahesh
2 Accepted Solutions
Anas Naqvi
Hi Mahesh,
Try using  ‘show dhcp summary’
For more information check the below link,
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html
Hi Mahesh,
Yes, this mean you have not configured your WLC to act as a DHCP server with pre-defined pools.
If clients getting IP address they should get it from an external dhcp server.
If you check the interface configuration you should see a DHCP server IP address configured. In CLI if you type "show interface detailed " that also provide the configured DHCP server information
Here is an example of such CLI output
(4402-3) >show interface detailed vlan130
Interface Name................................... vlan130
MAC Address...................................... 00:0b:85:43:d8:67
IP Address....................................... 192.168.130.33
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.130.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 130
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 192.168.130.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Rasika
7 Replies 7
Anas Naqvi
Hi Mahesh,
Hi Anas,
>show dhcp summary
No scopes defined
Does this mean that users are getting ip from the External dhcp device?
Mahesh
Hi Mahesh,
Rasika
Hi Rasika,
Thanks for the reply.
Mahesh
Thanks for rating useful responses...
Abhishek Abhishek
show capwap client ip config
To display the capwap static IP configuration, use the show capwap client ip config command.
Syntax Description
This command has no arguments or keywords.
Defaults
None.
Examples
This example shows how to display the capwap static IP information:
> show capwap client config
LWAPP Static IP Configuration
Primary Controller 9.41.80.88
Hi Abhishek,
Show capwap command is not available
>show c?
cac            call-control   cdp            certificate    client
coredump       country        cpu            custom-web
(Cisco Controller) >
Mahesh
