Questions regarding Flexconnect
DuJin0509
Level 3
Level 3
Hello every,
I am confusing regarding Flexconnect .
1. When AP disassociate to the WLC, the AP will divert to standalone mode aotomatically, right ?
2.when AP in standalone mode , the AP will authenticate the client by itself, right ?
3. In standalone mode, AP store authentication information in nonvolatile memory, is that means no radius server should be used for authentication ,only PSK can be used ?How about a new client want to connect a standalone AP ? What is the username and password should be used for this new client ?(assume this is the first time the client connect to this ap. )
4.In standalone mode ,We should deploy local DHCP server for client , right?  How to avoid IP overlapping ?  required an unique IP address space for this ?
Please kindly explain above question to me, Thank you very much .
Rasika Nayanajith
Yes
Only if your wlans is configured with "Local Authentication"
No, 802.1X also supported. In standalone mode, AP itself act as Authenticator & communicate with RADIUS server (it is assume RADIUS server still available even WLC is down). Refer this design guide
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.html#57480
Typically in FlexConnect, you terminate traffic locally in branch switches. So ideal to have DHCP service locally in branch.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Yes
Rasika
