09-17-2025 03:18 PM
Dear all,
There are 2 Access Points model 9166D1-ROW registered in a Cisco Catalyst 9800-CL Wireless Controller firmware 17.12.3. These APs looks like that are not emitting 5Ghz signal because no devices connect in 5Ghz frequency the devices connect only 2.4Ghz frequency. I can see in the 2.4Ghz Radios the option Operation Status up but to the 5Ghz Radio the option Operation Status down.
Has anyone had a similar problem and managed to solve it?
09-17-2025 11:49 PM
- - @remacamelo Verify the state of the AP country provisioning on the AP CLI with show controllers dot11Radio 1 to display the -ROW domain and the country to which the AP is assigned :
Look for this line in the output :
>Carrier Set:
Because when the -ROW access points that do not have a country code assigned the -ROW AP has its 5ghz radio shut down and the 2.4ghz radio operates on standard channels and lower power to avoid any country rule violation.
M.
09-18-2025 05:49 AM
Hello @Mark Elsen,
Thank you for your replay. I tried apply the command show controllers dot11Radio 1 but in the WLC I couldn't find this syntaxes
I work with Cisco Catalyst 9800-CL Wireless Controller.
I applied the command sh ap name (AP NAME) dot11 5ghz radio-reset stats and I received this output:
What can I do in this case?
09-18-2025 06:22 AM
- @remacamelo You need to apply the command show controllers dot11Radio 1 on the access point CLI
not the WLC. Further on make sure to assign a join profile to the access point
M.
09-18-2025 07:21 AM
can I have the 'show tech wireless' output from the WLC in a text file?
09-18-2025 07:36 AM
Hello @Mark Elsen,
Thank you for the explanation. I performed the command correctly now and the result is:
Radio Info Summary:
Radio: 5.0GHz
Carrier Set: (-RW) Brazil ( BR)
Base radio MAC: C4:18:FC:23:43:00
Supported Channels:
There are no supported channels.
09-18-2025 07:49 AM
- @remacamelo Do you have that country code provisioned in the join profile assigned to the AP. It must also be specified in the global controller configuration (?)
M
09-18-2025 08:56 AM
Please check if country code is configured under AP join profile.
show ap profile name <ap join profile name> detailed | i Country
09-18-2025 07:36 AM - edited 09-18-2025 07:37 AM
@remacamelo As per your problem description ,
Observations:
Can you please share below output from WLC CLI.
show wire country configured
show ap dot11 5ghz rf-profile summary
show ap slots | i <AP NAME>
show ap dot11 5ghz summary | i <AP NAME>
show ap name <AP NAME> config slot 1
show ap name <AP NAME> dot11 5ghz slot 1 radio-reset stats
