Radio Error Statistics
vanagon2tdi
Level 5
Level 5
I am running a Cisco WGB350 V8.65 and a Cisco 350 Series AP 11.07 (AP350-5737ac).
On my receive side i show 17174 +3 Duplicate frames and 1269639 +782 CRC errors . On the transmit side i see 552655 +178 retries, 252 max retries/frame, 36543 +29 excessive retries, 5 queue full discards and 21714 +8 holdoffs. I jsut cleared the counters on it and they are climbing back up stedily. My signal strength is IN 44 and OUT 39 and the Quality is IN 84 and OUT 74. The Noise level is -94dBm, 1 minute Max -94dBm Avg -94dBm.
Can anyone tell me what type of issues i am probably looking at?
Thanks.
Dave
pradeepde
Level 11
Level 11
Check if you have any other devices that operate in the same wireless bandwidth.
