12-24-2010 08:31 AM - edited 07-03-2021 07:35 PM
I have one Air-lap1131-a-k9 and i convert in autonomus system , but when the AP reload the message " the interface radio is not present " apper
so when i type sh run the interfaces radio dont apper...
Please help me
12-24-2010 09:15 AM
This is a defective hardware... u need to replace the device..
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
12-24-2010 09:20 AM
wait.. lemme see.. paste required the outputs.. "sh ip int br" and "show version"
Surendra
12-28-2010 06:26 AM
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:40 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 150 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 10304512
flashfs[1]: Bytes available: 5694464
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0 not present 0 0 0 0 0 3
Radio1 not present 0 0 0 0 0 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. AIR-LAP1131AG-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FTX1253N1KJ
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
If
cisco
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:23:04:B7:BA:8C
Part Number : 73-8962-14
PCA Assembly Number : 800-24818-13
PCA Revision Number : A0
PCB Serial Number : FOC125002LQ
Top Assembly Part Number : 800-29144-03
Top Assembly Serial Number : FTX1253N1KJ
Top Revision Number : A0
Product/Model Number : AIR-LAP1131AG-A-K9
Press RETURN to get started!
*Mar 1 00:00:06.194: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS SOFTWARE (fc1)
*Mar 1 00:00:54.649: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar 1 00:00:55.601: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
ap>
ap>
ap>en
Password:
*Mar 1 00:01:06.553: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:01:07.553: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
Password:
ap#sh run
Building configuration...
Current configuration : 731 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$yzUD$BN8tHBfXumwWzTMN9YDj20
no aaa new-model
dot11 syslog
username Cisco password 7 1531021F0725
bridge irb
--More-- !
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
--More-- line vty 0 4
login local
end
ap#
ap#sh hardware
SOFTWARE (fc1)
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (
fc2)
ap uptime is 3 minutes
System image file is "flash:/c1130-k9w7-mx.124-21a.JY/c1130-k9w7-mx.124-21a.JY"
If
cisco
Configuration register is 0xF
ap# sh un
ap# sh inv
ap# sh inventory
NAME: "AP1130", DESCR: "Cisco Aironet 1130 Series (IEEE 802.11a/g) Access Point"
PID: AIR-LAP1131AG-A-K9, VID: V05, SN: FTX1253N1KJ
12-28-2010 03:04 PM
12-25-2010 09:33 PM
The 1131 only has ONE radio: Dot11Radio0
It's only 802.11b (2.4Ghz).
