12-20-2011 07:04 AM - edited 07-03-2021 09:16 PM
Any idea on how I can get this "Installed"? I am trying to get guest wirelss setup but can't without both radios installed. Any help is greatly appreciated.
12-20-2011 07:06 AM
Eric,
What model access point do you have ?
12-20-2011 07:23 AM
AIR-AP1220G Series
12-20-2011 07:31 AM
I was afraid of that .. Thats your problem. That access point only has 1 radio which is the 802.11 b/g 2.4GHz.
12-20-2011 07:34 AM
All the config docs I have looked at say I can have multiple ssid's with this WAP. It even says I can have 8 in the config. What I am trying to do is get a guest wireless setup.
12-20-2011 07:42 AM
Thats different
You asked why you didnt see radio1 and thats the 5 GHz radio. Thats why you dont see it becuase your AP doesnt support it.
As for your last post, yes you can add additional SSIDs to your access point. And you can add them under your radio 0. Is this the first time you are setting up a SSID on a autonmous access point ? Are you using that access point for anything else?
12-20-2011 07:46 AM
See, that's what I tought! The problem I am runninng into is that evet config doc I look at wants the main SSID on radio) and the guest on Radio1. I am using this at home, but I have a lot of people that come over and use my wireless, I would like to keep them off my internal network and on the guest vlan.
12-20-2011 07:53 AM
Oh, then just substitute radio 1 for radio 0 then in the config example.
I hope this helped ...
12-20-2011 07:54 AM
Tried that, it doesn't work. It will only broadcast 1 SSID.
12-20-2011 07:58 AM
Did you add the mbssid guest mode command on your guest SSID ?
12-20-2011 08:00 AM
Not sure, I can try it again. I'm pretty sure it stopped broadcasting the primary when i tried to broadcast the guest.
12-20-2011 08:27 AM
It would have, by default you can only broadcast one ssid. To get around this
Conf t
dot11 mbssid
int dot11radio0
mssid
then under the SSID
mbssid guest-mode
Though, I would only broadcast the 'guest' network, not that it makes the 'private' anymore secure. Then anyone on your 'private' would then need to configure the SSID and encryptions and not just click on it and enter the key.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
12-20-2011 07:58 AM
https://learningnetwork.cisco.com/thread/25093
12-20-2011 08:39 AM
Well, I've got 2 ssid's, one is my guest wireless, but the other one broadcasts as "Other Network". Any ideas??
12-20-2011 08:48 AM
I'll assume that your 'private' isn't named Other network.
So what you're seeing is the supplicant telling you there is a WLAN there, but that the SSID is not being broadcasted, so it can't tell you what it is. So working as designed for that piece at least.
HTH,
Steve
