Radius accounting for https
nikhilcherian
Level 8
Level 8
Hi All,
I would like to enable HTTPS access for my access points. It can be done with ip http secure-server. Along with the same I would like to enable accounting for the https access. Is there any way for the same
NikhiL
jeff.kish
Level 11
Level 11
Normal AAA commands should work:
http://www.cisco.com/en/US/docs/ios/12_2/security/command/reference/srfathen.html
HTTP aaa uses Telnet/VTY configuration. Try that and see if it works.
Jeff
I was wondering if it deal with only http or both http and https
NikhiL
