RADIUS (ACS) and WCS Authentication
kev-matthews
Hi Folks,  I'm attempting to configure my Cisco ACS 4.1 for RADIUS authentication of the WCS Web administration login page.  Due to the ACS server having a weird TACACS issue, it doesn't like TACACS+ requests - but RADIUS seems to work ok.  My question is: How do I import the task lists into the ACS so I can assign user roles?  My WCS is V7.0.164.0.   I've found some articles on remotely importing RADIUS attributes by FTP, but I just can't work out the format for the User roles and tasks.  If anyone can offer any advice (or even pre-formatted csv files) I'd really appreciate it.  Thanks in advance  Kev
Tiago Antunes
You can find usefull guidance with screenshots here:
http://www.cisco.com/en/US/docs/wireless/wcs/7.0/configuration/guide/7_0admin.html#wp1059965.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Tiago Antunes
HTH,
Tiago
Thanks Tiago - that's got it! Kev
