Radius-base VLAN access control.
c.ong
Level 3
Level 3
Hi Sir,
I would like to use Radius-based Vlan access control through WLAN as the number of SSID map to wired VLAN is limited to only 16. I have an ACS 4.0 But i wish to use AD to manage my user profile. How can I set the following to enable Radius-based VLAN access control?
IETF 64 (tunnel Type)-set this to 'VLAN'
IETF 65 (tunnel Medium Type)- Set this to '802'
IETF 81 (tunnel Private Group ID)-set this to VLAN-ID
Or Radius-based VLAN Access Control can only be achieved when local user database is stored in ACS.
Please advise.
Thank you.
Delon
johnruffing
Level 7
Level 7
Keep in mind that if you are using Cisco access points (1230, 1242AG, 1131AG) you will only have eight VLANs available.
