Radius Connection Behavior
darkmagex
Community Member
Test clients running Widnows 7.
Both APs connect to the same RADIUS server (Windows IAS)
AIR-AP1131AG-A-K9
12.4(25d)JA
AIR-AP1142N-A-K9
12.4(21a)JA1
The 1142 clients when connecting get a login prompt, and when entering a valid login then get the "authorize certificate" prompt. After accepting they connect. This is how fro my knowledge a first time connection should work.
The 1131 clients when connecting get a login prompt,which fails. If these clients manually build a wireless profile they get the above behavior and can connect, if not they are unable to connect.
Is there any reason that seeminly 1 APs clients are able to autodetect the settings and anothers is not? I can't see how this is a model/firmware issue but not positive. Both APs are running same encryption settings under the SSID.
0 Replies 0
