RADSEC Issues
Henry-M
Community Member
Has anyone seen the folloiwng issue? We're running 30.7 on an MR44 when testing.
When using Radsec we see this 802.1X error.
The client will eventually connect and stay connected.
7 Replies 7
mloraditch
Meraki Community All-Star
I've seen the error but only when it wasn't working period.
FYI the 127.0.0.1 IP is due to the architecture of the RADSEC. The APs use some sort of proxy in their code to implement RADSEC, so the dashboard will show the localhost IP instead of the actual IP. It definitely confuses troubleshooting. The error could be within the AP RADSEC functionality or still be a normal error with connectivity or your RADIUS server.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
joey.debra
If you're using a cloud based radius having a few failed auth's in between happens quite alot. It's best to look at the logs of your radius service to see why it rejected that auth.
HenkDirksen73
Community Member
"We have been experiencing this problem since using SCEPman and RADIUSSaaS:
'Client failed 802.1X authentication to the RADIUS server. authmode='wpa2-802.1x' vlanid='16' radiusproto='ipv4' radiusip='127.0.0.1' reason='radiusloginfailure' reassoc='1' radio='1' vap='3' channel='48' rssi='52'.
We have tested the beta firmware in collaboration with Meraki Support, but it was a complete disaster. The current firmware works with the caveat of some of these messages. Downgrading the access point to the current firmware has unfortunately permanently damaged the access point; firmware downgrade, factory reset, none of it helped. Users can no longer connect to the SSID with radsec active on this specific access point."
That sounds just like the issue I had with all the errors getting logged. I'm having to use a RADIUS proxy in RADIUSaaS as a work around, which is far from ideal. I'm going to raise this again with Meraki support but they've been no help so far.
markd-bit
Community Member
Hi all, im having a similar issue with an MR20. We have over 600 sites and it's only affecting one site where radsec refuses to work. Have had to switch to RADIUSaaS proxy at the moment. We have other sites with MR20's working fine.
The AP has firmware 30.7.1 and i've also got a ticket open with support.
Did anyone manage to get to the bottom of this?
markd-bit
Community Member
Just to provide an update, they have told me this is known bug fixed in 31.1.6 but as this AP can only go up to 30.7.1 they have a custom firmware which can be installed. It locks the device to this version though, doesn't sound very good as a long term solution.
AlexanderMorgan
Community Member
I am also having the same issue with a CW9164I access point running firmware version "MR 31.1.8". This has resulted in using a RADIUSaaS proxy as a work around.
