RAL color of outdoor access points
dglaser
Our architects need the RAL color code of actual outdoor APs.  If it not fits, the APs should be painted. As I understood right, we then we will loose warrently.
All I found so far, outdoor APs have Cisco Medium Gray color. Cisco Medium Gray 2 (another color?) corresponds to PMS Color Gray 7. And  this color corresponds to RAL 9022 perl light gray / metallic. Is that right?
Dietmar
JPavonM
To avoid losing warranty, you may be looking at this:
https://www.acceltex.com/skins/
JPavonM
Hello Jesus,
thanks. It looks like a good alternative to painting.
