Re-sizing, re-scaling maps in MSG
nh6we
Can someone tell me how to re-scale/re-size a map in NCS.  I have just got MSG running but have noticed my map/drawing are not sized correctly.
Thanks for any help
Richard Atkin
Level 4
Level 4
What's MSG?
In order to re-size a map there are two things to worry about, the floorplan and the building.
If you're trying to make your current plan bigger, increase the size of the building first, followed by the floorplan.
If you're trying to make your current plan smaller, decrease the size of the floorplan first, followed by the building.
The building is edited by going to the MONITOR > MAPS page, clicking the tick box next to the building you're concerned with, and then selecting Edit Building from the drop-down menu at the top right.
Floor plans can be edited in much the same way, or you can open the plan in the editor and use the scaling tool. The scaling tool allows you to draw a line on the map, and to then tell WCS how long that line is in Meters or Feet. (Ie, measure the length of a room and the transpose that information to WCS)
