RE : Wireless AP Overlaps??
chialun
Level 6
Level 6
Dear Sir,
Just want to check with you, based on the attached diagram. Please advise which channel is should apply for the AP. The AP signal sure will overlaps with each others, so how's the client will exprience? will the signal clash and got problems? please advise.
chialun
Level 6
Level 6
Dear Sir,
For your informations , the AP model is AIR-AP1121G-A-K9 . PLease advise. Thank you very much.
